CHOP CULT HOME
Email Password
Search
Page 1 of 2 12 Last
  1. #1
    Member
    Get Adobe Flash player
    Join Date
    Sep 2015
    Posts
    64
    Default Shovelhead Shuts Down When Hot
    Looking for some ideas as to what could be happening with my bike now. It's a '73 Super Glide in a hardtail frame, ratchet top trans, Super E carb, kick only. It starts right up in one or two kicks very time when cold, then after about 20 minutes of riding starts to misfire and pop out of the exhaust. It gradually gets worse and worse until the bike just shuts down and will not start again until it has had some time to cool.
    So far I have put a new coil on, new points and condenser, plugs and plug wires, checked and redone timing, checked pushrods, new battery a few months ago, but the problem is still there. I recently switched to the Super E from a CV after the same problem thinking it might have been the culprit, but the bike seems to like the E better when it's running so I kept it. Put new intake O rings on when I changed carbs. The wiring was redone a few months ago when the bike was put together in the hardtailed frame. I've been digging through other threads with similar issues and have found a similar story being solved by replacing the advance unit and weights which I am going to try next. I have not had any engine work done since owning this bike and am unsure of the history behind it. I also haven't changed the regulator. Could the problem be related to the engine itself? Regulator? Battery? Any input or ideas are appreciated.
  2. #2
    Senior Member
    Join Date
    Apr 2010
    Posts
    2,402
    Default
    Short
  3. #3
    Senior Member
    Join Date
    Sep 2012
    Posts
    12,047
    Default
    Weak battery...........
  4. #4
    Join Date
    Dec 2018
    Posts
    1,596
    Default
    Quote Originally Posted by BuddhahoodVato View Post
    Short
    Ding ding ding. ^^^
    Wire in the harness shorting through the insulation when hot. It happens. I just fixed (I hope) a similar problem. Harness at the handlebar switches ('96 - up style) were pinched where they should not have been. Ran perfectly until fully hot, about a half hour.
    Jim
  5. #5
    Member
    Join Date
    Sep 2015
    Posts
    64
    Default
    Quote Originally Posted by Tattooo View Post
    A weak battery would fire right up fine then cause these symptoms after riding for a bit?
  6. #6
    Member
    Join Date
    Sep 2015
    Posts
    64
    Default
    Quote Originally Posted by JBinNC View Post
    Ding ding ding. ^^^
    Jim
    Thanks Jim. I will take a look through the whole harness asap and check for shorts.
  7. #7
    Member
    Join Date
    Sep 2015
    Posts
    64
    Default
    Another thought related to that – if it were a short, wouldn't this cause the bike to immediately shut off rather than a slow decrease in performance, misfiring and popping over the span of a few minutes ultimately leading to a shut down?
  8. #8
    Senior Member
    Join Date
    Oct 2012
    Posts
    103
    Default
    Could be a condenser getting ready to let go. Just because they're new doesn't mean they're good, they can break down on the shelf.
  9. #9
    Senior Member
    Join Date
    Sep 2012
    Posts
    12,047
    Default
    Quote Originally Posted by HogsRear View Post
    Damn right it will........ Especially on a kick bike with points..................
  10. #10
    Senior Member
    Join Date
    Feb 2014
    Posts
    584
    Default
    Is your tank vent plugged?
  11. #11
    Member
    Join Date
    Sep 2015
    Posts
    64
    Default
    Quote Originally Posted by metalheart28 View Post
    Tank vent seems to be working fine, no difference in performance with gas cap off while running
  12. #12
    Default
    I just experienced this. I run a Dynatek S though.... Bike ran great on the highway but once I got into town it would sputter and backfire. Let it sit for 10 minutes and kicked right over again only to start running bad again in a minute or so. Wouldn’t start a third time though.
    Had a bad AGM battery.
  13. #13
    Senior Member
    Join Date
    Sep 2012
    Posts
    12,047
    Default
    Quote Originally Posted by Micromark View Post
    Wouldn’t start a third time though. Had a bad AGM battery.
    It's astounding what problems a weak battery will cause......
  14. #14
    Member
    Join Date
    Sep 2015
    Posts
    64
    Default
    Alright I have ordered a new sealed battery to replace the current lead acid battery I got from NAPA, hoping that it helps. Going to look over the wiring this weekend and see if there are any weak spots or pinched wires. Thanks all!
  15. #15
    Senior Member
    Join Date
    Sep 2012
    Posts
    12,047
    Default
    Did you happen to check it to see if it was bad???????????? Or are you just going to assume it's bad??????
  16. #16
    Member
    Join Date
    Sep 2015
    Posts
    64
    Default
    It tested ok not running but I wanted to switch to a sealed battery that fits in the oil bag a little better anyways so I will keep the old one as backup.
  17. #17
    Senior Member
    Join Date
    Dec 2017
    Posts
    2,531
    Default
    If your alternator and regulator are operating as intended, don't even need a battery with your points type ignition.
  18. #18
    Join Date
    Oct 2018
    Posts
    259
    Default
    Are you still getting a spark on both cylinders after the motor shuts down? Is there fuel in the carb's bowl after the motor shuts down? I have yet to see any results from attempting to diagnose the problem.
  19. #19
    Member
    Join Date
    Sep 2015
    Posts
    64
    Default
    Quote Originally Posted by Skjoll View Post
    Yes and yes.
  20. #20
    Join Date
    Oct 2018
    Posts
    259
    Default
    What you've described sounds so much like inadequate or zero valve clearance when cold so as the motor heats up and the valve gear tightens up, the valves are prevented from closing completely until they remain open far enough that you no longer have adequate compression for the air/fuel mix to ignite.
Share This
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Log in
Log in
