- Forum
- American Bikes, Build Threads
- Peoples Champ 5 Hot rod knucklehead build
02-15-2017 #1
Disclaimer: There will be very few original knuck parts in this build. If that is not your thing you can stop looking now. I'm building with speed as the primary concern.
I picked these heads up last year, and realized it was time to build my dream knucklehead. Heads are dual carb flathead power designed to use a evo style piston
Got some 3 13/16" trock cylinders, and a lienweber cam. I will be using a 4 3/4" inch stroke flywheels for a 108.5" final displacement.
02-15-2017 #2Member
- Join Date
- Oct 2010
- Posts
- 52
Got a panhead frame and stretched it up 2", and deraked it to 27 deg
02-15-2017 #3Member
- Join Date
- Oct 2010
- Posts
- 52
02-15-2017 #4Member
- Join Date
- Oct 2010
- Posts
- 52
02-15-2017 #5Member
- Join Date
- Oct 2010
- Posts
- 52
02-15-2017 #6Member
- Join Date
- Oct 2010
- Posts
- 52
I have kept a much more detailed build thread over at the other site if your interested....
http://www.jockeyjournal.com/forum/s...d.php?t=183449
I will be keeping this thread updated regularly now.
Thanks for looking!
02-15-2017 #7Senior Member
- Join Date
- Sep 2016
- Posts
- 324
Sounds pretty cool, can't wait to see where you go with this
02-18-2017 #8Senior Member
- Join Date
- May 2014
- Posts
- 3,357
when your done can you you tube the motor runing, I would love to hear her growl..
nice build
02-18-2017 #9Senior Member
- Join Date
- Aug 2009
- Posts
- 2,892
Kick only? 108" is allot of motor for a leg. watch out when she kicks.
Looks like the beast is essentially an EVO with knuckle looking rocker boxes.
I don't have any problem with that at all, especially if She rips, & She probably will.(big time)
nice choice on the cam & ignition.
02-19-2017 #10Member
- Join Date
- Oct 2010
- Posts
- 52
02-19-2017 #11Member
- Join Date
- Oct 2010
- Posts
- 52
02-19-2017 #12Member
- Join Date
- Oct 2010
- Posts
- 52
Lots of similarities to an evo, but heads are still cast iron and rocker ratio is still 1 to 1. My research leads me to believe that these were the same design heads used on the 120" drag knuckle "evil mother"
02-20-2017 #13Senior Member
- Join Date
- Mar 2015
- Posts
- 215
Yes it's kick only, curious to see how she kicks over.... Lots of overlap in the cam so hopefully not to bad. Hope it doesn't kick back often cause that 4 3/4" stroke will make a nasty kick back.
02-21-2017 #14Member
- Join Date
- Oct 2010
- Posts
- 52
Got a mock up motor together so I could make my exhaust. Decided it was time to get it off the lift and take some pictures.
02-25-2017 #15Senior Member
- Join Date
- Mar 2015
- Posts
- 215
Wow! Should be a fun ride! What are you running for a transmission? I can't get a good look on my phone, but it looks like a 5in4?
02-27-2017 #16Member
- Join Date
- Oct 2010
- Posts
- 52
03-01-2017 #17Senior Member
- Join Date
- Oct 2012
- Posts
- 136
Did you modify the seat post to get that straight backbone? Looks like some haz in the earlier pics, low on seat post, also backbone is high above rear head. Thanks
03-01-2017 #18Senior Member
- Join Date
- Mar 2015
- Posts
- 215
I thought that looked familiar. I LOVE the case on the signature series. It looks like an old 6-71 roots type blower. I just put a 6 into 4 in my chop, and I must say they are worth every damn penny.
03-01-2017 #19Member
- Join Date
- Oct 2010
- Posts
- 52
Seat post was cut, lifted up and then bent down in the upper rear legs until the back bone was straight front to back. Had to add extra material to the seat post and backbone for it all to meet up right.
03-10-2017 #20Member
- Join Date
- Oct 2010
- Posts
- 52
I end up running a set of chopper Dave pegs on all my bikes
Share This
Quick Navigation
Top
- Site Areas
- Settings
- Private Messages
- Subscriptions
- Who's Online
- Search Forums
- Forums Home
- Forums
Previous Thread
Next Thread
