Thread: Kandy
10-17-2014 #1
Kandy
Yup. Naming it Kandy. Everything ends up with a name, my other bikes are named after whores, figured since this one is supposed to end up naked and loud, I'll name it after a stripper.
Now that thats out of the way.
After I got back from the Greasy Dozen run, I was already itching to build another bike, had a buddy tell me I should come to born free, long story short my wife and kids are all for it, so we're building another bike. I've never owned a Harley, built a harley, they're just not really my thing............But a kick start shovel is a bucket list bike for me so this all works.
A buddy of mine is in the woods trying to get me my motor this weekend, so for now you can get the same thing that Show Class Mag got for my Peoples Champ entry, some fancy pictures, and my ideas............
The frame is going to be all stainless. I want the tins to be aluminum, finish work in a mix of those and brass. No paint is currently the plan. Everything raw.
Front end will be a spoolie made by Derek Seiber, if you guys are on instagram, you should check him out. Stupid talented.
http://instagram.com/derekseiber
The front trees I'm going to have Derek make too, I've had an idea for a long time I wanted to try, this may or may not work as planned, but hell, I've tried worse.
Planning an invader with a juice drum out back. And same as my last build, not buying anythign I can make myself. Everything will be scratch built.
10-17-2014 #2Senior Member
- Join Date
- Mar 2010
- Posts
- 1,965
Since I dont have my motor yet, I figured I could at least get started on stuff I dont need it for. So we stopped by the steel shop and grabbed a nice fat pieceof stainless.
Me and the boy chucked it up in the lathe and started whittling out a neck. Got called away for dinner, so I'll get it finished tomorrow.
10-18-2014 #3Senior Member
- Join Date
- Aug 2011
- Posts
- 316
In for the win.
10-18-2014 #4Senior Member
- Join Date
- May 2012
- Posts
- 251
Cant wait to see how this turns out. You are stupid talented too looking forward to that tin work mainly
10-18-2014 #5
Very cool, looking forward to watching the build. Looks like you're going with an extreme narrow glide. Love that frame too!
10-18-2014 #6Senior Member
- Join Date
- Mar 2010
- Posts
- 1,965
Thanks. And yeah, the front end will be real narrow. Its a concept I've been playing with for a while, that I've never seen done..........That usually means there's a reason, but I have to try anyways........
Basically I'm going to take a pair of these.............
And have the trees made to accomadate them. They're a nitrogen charged air shock (no spring) that is completely rebuildable, and tuneable. They're a ton cleaner than an inverted front end, and should work as well as they look. I can strip the anodizing and polish them out, and since I'm going to run a spool hub anyways, they're already clean of any brackets. They've also basically got an internal bumpstop so they're not bottoming out quite as hard if I start riding it like a dirt bike.
After a morning at home me and the boy snuck up to the shop and finished the neck. Just needs a little more sanding and a polish.
10-18-2014 #7Senior Member
- Join Date
- Feb 2014
- Posts
- 705
So you're telling me you're like 11 and you can do CAD drawings and lathe metal at a higher skill than I can dream of?
Just yanking your chain. Sub'ed to the thread, can't wait to see where this goes
10-19-2014 #8Senior Member
- Join Date
- Nov 2009
- Posts
- 672
Shoot, You had me at stainless...
10-19-2014 #9Senior Member
- Join Date
- Mar 2010
- Posts
- 1,965
So I downloaded this blueprint while I was programming, and then realized that its the same one that Boomboomthump posted in the shovel blueprints thread.......So since people keep skipping out on me on motors, I want to start mocking up the frame next week wether I have my drivetrain or not.
So the question is. If I build a jig for the trans and motor mounts, I should be able to use these drawings for the frame and not worry about the engine fitting? I know they're panhead drawings, but pan/shov would obviously be the same, what about cone shovel? Or evo(shudder) if all of these shovels dont pan out...........Just dont want to jump the gun if its going to bite me in the ass once I get my actual drivetrain.
10-19-2014 #10Member
- Join Date
- Nov 2013
- Posts
- 67
The engine mounts themselves will be the same. The seat tube and backbone may be an issue for an evo if the frame is designed for a pan. The trans plate is going to be different for four or five speed.
10-19-2014 #11Senior Member
- Join Date
- Mar 2010
- Posts
- 1,965
Planning on a 4 speed anyways, but since I'm not following the blue print It should be easy enough to make sure the seat tube clears, and the backbone will be high, I can just wait on the brace until I get the motor in.........Good news for me. Thanks.
10-20-2014 #12Senior Member
- Join Date
- Oct 2011
- Posts
- 241
If you run an Evo, as well, you gotta watch the exhaust around the front leg, too... it doesn't point straight down like on a Shovel.
10-21-2014 #13Senior Member
- Join Date
- Mar 2010
- Posts
- 1,965
Finished laying out my frame jig. May as well do it right this time, or at least better than before, so planned ahead, and made a shovel silhouette that will bolt to the motor mount jig so I can build the frame without the motor and check clearances still.
My boy turned down some neck cones, and polished the neck while he was at it, and we burned the pieces for the jig this afternoon.
Tomorrow I'll do a hardware run and hopefully have the jig ready tomorrow night.
10-22-2014 #14Senior Member
- Join Date
- Oct 2011
- Posts
- 241
You're way over my skill level, bud.
I'll be watching this.
10-24-2014 #15Senior Member
- Join Date
- Mar 2010
- Posts
- 1,965
Got my frame jig part way finished. Had to head home so I worked on designing the neck details while I finished programming the triple trees.
10-24-2014 #16Senior Member
- Join Date
- Jul 2011
- Posts
- 549
This is gonna be a ridiculous thread! Your skill level is amazing, looking forward to watching this come to life.
10-24-2014 #17Member
- Join Date
- Oct 2014
- Posts
- 31
Like others, I wish I had your skills. Looking forward to more! Great work!
10-24-2014 #18Senior Member
- Join Date
- Mar 2010
- Posts
- 1,965
Grabbed some stainless to start making some of these fake pictures real........
10-26-2014 #19Senior Member
- Join Date
- Mar 2010
- Posts
- 1,965
Got the brass in and got a half ass polish on it for now, do the other one tomorrow.
Should have everything ready to go as soon as my material is in at least.
10-27-2014 #20Senior Member
- Join Date
- Feb 2013
- Posts
- 112
Share This
Quick Navigation
American Bikes, Build Threads
Top
- Site Areas
- Settings
- Private Messages
- Subscriptions
- Who's Online
- Search Forums
- Forums Home
- Forums
Previous Thread
Next Thread
